Product
Cables Direct UK Single Back Box - 86mm x 86mm x 32mm - B/Q 200
Quicklinx: CCBCWS00 Mfr#: UT-722A
More than 50 in stock
£0.39 ex VAT
£0.46 inc VAT
Standard delivery Delivered within 3-5 working days
The UT-722A is a surface mounting single back box for 86mm wide faceplates. Has multi in and out points allowing easy access, 32mm deep to allow enough cable bend for most applications.
Cables Direct UT-722A - back box
Back box
Package Content
2 x screws
8.6 cm x 8.6 cm x 3.2 cm
Product Material
Plastic
Back box
Package Content
2 x screws
Product Material
Plastic
8.6 cm
8.6 cm
3.2 cm
Enclosure Colour
White
Brand: Cables Direct
Price Range Ex VAT: 0 - 50
