Product
Cables Direct UK Single Back Box -  86mm x 86mm x 45mm - B/Q 100
Quicklinx: CDQNWS00 Mfr#: UT-724D
More than 50 in stock
£0.58 ex VAT
£0.69 inc VAT
The UT-724D is a surface mounted single back box for 86mm wide faceplates. Has multi in and out points allowing easy access, 45mm deep to allow enough cable bend for most applications.
Cables Direct UT-724D - back box
Back box
Package Content
2 x screws
8.6 cm x 8.6 cm x 4.5 cm
Product Material
Plastic
White
Back box
Package Content
2 x screws
Product Material
Plastic
8.6 cm
8.6 cm
4.5 cm
Enclosure Colour
White
Brand: Cables Direct
Price Range Ex VAT: 0 - 50
