Cables Direct SERIAL ATA CABLE 0.4m
Reduced Price - Whilst Stocks Last!
Customer rating: 5.0* (Write a review)
Quicklinx: 2MY8WS00 Mfr#: RB-404
The concept of Best Value is to offer customers the best value product, sourced from a variety of manufacturers all over the world, in any given category, at any point in time. The products selected for our Best Value range are carefully evaluated in terms of price, performance and manufacturing quality before they make it onto our website. Although certainly a 'value' brand, Best Value products are never inferior quality... just superb value for money.
Serial ATA (or SATA) has been designed as a replacement for the existing 40 way IDE cable, the SATA connector and cable are smaller (which improves air circulation), with a reduced operating voltage and pin amount (7 as opposed to 40), the current data transfer rate is ATA-150 (1.5Gbps).
Red
Length
0.4
Customer reviews
Write a review for the Cables Direct SERIAL ATA CABLE 0.4m here!
Does the job
Reviewed by Dan Houghton. Review Posted 09/01/2007
Powers my new SATA hard disk fine, but a warning to other owners of Dell Dimension 5100's and other computers with hard disk trays near the case: The cable sticks out a good few centimetres - I can't put the case back together as this cable is in the way.
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
Does what it says on the tin..
Reviewed by Lee. Review Posted 19/03/2007
Great little cable. Works perfectly. Don't waste your money on more expensive cables when this one does the job!
  • Overall 5*
  • Ease of use 5*
Caution Dell Dimension E520 owners
Reviewed by Mark. Review Posted 02/04/2007
As noted by Dan, the cable functions electrically perfectly well and is good value. However, I also ran into the problem with closing the side panel , but this was on a Dell Dimension E520. Dell use a right-angle cable for their pre-fitted drive.
  • Overall 5*
  • Ease of use 5*
Read all 5 customer reviews
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
