The UK to IEC C15 mains cable, more commonly known as a kettle lead is used for powering a variety of electrical appliances such as PC base units, monitors, printers & photocopiers and a whole host of other equipment including high temperature devices such as kettles.
The C15 connector, although similar in appearance to the C13 has a higher temperature rating of 170 degrees rather than 70 degrees. You can tell the difference between a C13 and a C15 connector by the notch in the connector; this means a C15 plug will work with a C14 and a C16 socket. A C13 plug however will only work in a C14 socket.
- Cables Direct - power cable - IEC 60320 C15 to BS 1363 - 2 m
- Power cable
- Fuse, rubberised
- Length
- 2 m
- Localisation
- United Kingdom
- Connector
- Power IEC 60320 C15
- Connector (Second End)
- Power BS 1363 - male
- Rated Voltage
- AC 250 V
- 1-year warranty
- Power cable
- Rated Voltage
- AC 250 V
- Fuse, rubberised
- Length
- 2 m
- Localisation
- United Kingdom
- Connector
- VDE, BSI, ASTA
- 1-year warranty
