Cables Direct Newlink Impact 110 Puch Down/Insertation Tool B/Q 100
Quicklinx: BYW7WS00 Mfr#: NLCN-316
Used to install wires easily into a telephone socket, Cat5e faceplate or patch panel. Includes tool ends for cutting, stripping and inserting. Can be used for both UTP and FTP cables.
  • Integrated, spring loaded blade cuts off excess automatically
  • Small hook to remove any existing wires from socket
  • Small blade to cut and strip wires to a desired length
NEWlink punch-down tool
Punch-down tool
Punch-down tool
Cabling & Wiring
Additional Functions
Cut, installation
