The USB3C-HUB3CR is a USB-C to three USB 3.0 hub with a Micro SD and SD/MMC port. The USB 3.0 port allows you to connect a USB device or another hub to the host USB-C computer, the Micro SD and SD/MMC port allows you to access memory cards on the host PC. It can work with Macbook’s or Google’s Chromebook Pixel as well as other USB-C supported devices.
- Cables Direct USB3C-HUB3CR - hub - 3 ports
- Hub - 3 ports
- Subtype
- USB
- Ports
- 3 x SuperSpeed USB 3.0
- USB 2.0, USB 3.0
- 1-year warranty
- Hub - 3 ports
- Enclosure Type
- Desktop
- Subtype
- USB
- Ports
- USB 2.0, USB 3.0
- Built-in Devices
- microSD card reader, SDXC card reader
- 3 x USB 3.0 Type A , 1 x USB-C input Type C
- Cables Included
- 1 x USB-C cable - 15 cm
- Limited warranty - 1 year
