The IEEE-EXT5 active repeater cable allows users to extend past the 5 Mtr limit of Firewire without using powered hubs, the cable can be cascaded up to 10 times, allowing a possible extension of up 50 Mtrs using 10 separate cables.
It is compatible with the High Performance Data Rates of the IEEE 1394A specification, supports 100 / 200 / 400 Mbps. Compliant with IEEE 1394-1995 and 1394A Specification.
- Cables Direct IEEE 1394A Active Extension Cable - IEEE 1394 (FireWire) extender - Firewire
- IEEE 1394 (FireWire) extender - 6 PIN FireWire / 6 PIN FireWire
- Form Factor
- External
- Data Transfer Rate
- 400 Mbps
- Data Link Protocol
- Firewire
- Max Transfer Distance
- 50 m
- Form Factor
- External
- Connectivity Technology
- Wired
- Firewire
- 400 Mbps
- 50 m
- 1 x FireWire - 6 pin female , 1 x FireWire - 6 pin male
- Cables Included
- 1 x IEEE 1394 cable - 5 m
