Cables Direct IEEE 1394A Active Extension Cable IEEE 1394 (FireWire) Extender - IEEE 1394 (FireWire)
Quicklinx: 7Z4JWS00 Mfr#: IEEE-EXT5
£20.19 ex VAT
£24.22 inc VAT
The IEEE-EXT5 active repeater cable allows users to extend past the 5 Mtr limit of Firewire without using powered hubs, the cable can be cascaded up to 10 times, allowing a possible extension of up 50 Mtrs using 10 separate cables.
It is compatible with the High Performance Data Rates of the IEEE 1394A specification, supports 100 / 200 / 400 Mbps. Compliant with IEEE 1394-1995 and 1394A Specification.
Cables Direct IEEE 1394A Active Extension Cable - IEEE 1394 (FireWire) extender - Firewire
IEEE 1394 (FireWire) extender - 6 PIN FireWire / 6 PIN FireWire
External
Data Transfer Rate
400 Mbps
Firewire
Max Transfer Distance
50 m
External
Wired
Firewire
Data Transfer Rate
400 Mbps
50 m
1 x FireWire - 6 pin female , 1 x FireWire - 6 pin male
1 x IEEE 1394 cable - 5 m
Brand: Cables Direct
Price Range Ex VAT: 0 - 50
