DisplayPort is a 20 pin connector similar to HDMI but designed to replace DVI/VGA. The standard was put forward by VESA to define a new royalty free audio/video connection.
Our DisplayPort to VGA cables are the perfect solution for adapting your DisplayPort computer or graphics card to use a VGA monitor/device.
- Cables Direct DisplayPort cable - 2 m
- DisplayPort cable
- Length
- 2 m
- Connector
- DisplayPort - male
- Connector (Second End)
- HD-15 - male
- 1 year warranty
- DisplayPort cable
- Length
- 2 m
- Connector
- 20 pin DisplayPort - male
- 15 pin HD D-Sub (HD-15) - male
- DisplayPort 1.1
- 1 year warranty
