Cables Direct DISPLAY PORT MALE - HDMI FEMALE ADAPTOR
Quicklinx: 64CZWS00 Mfr#: HDHDPORT-005
The concept of Best Value is to offer customers the best value product, sourced from a variety of manufacturers all over the world, in any given category, at any point in time. The products selected for our Best Value range are carefully evaluated in terms of price, performance and manufacturing quality before they make it onto our website. Although certainly a 'value' brand, Best Value products are never inferior quality... just superb value for money.
ADAPTOR, DISPLAYPORT M - HDMI F
DisplayPort is new technology in High Definition digital audio and video connections, which is intended to be used between a computer and its monitor, or a computer and a home theatre system. DisplayPort is very simple to use and makes connecting your PC to your TV for High Definition images very easy.
  • Supports conversion from DisplayPort signal to HDMI signal
  • Supports DisplayPort connector 20 pin
  • Supports 8-bit &10-bit Deep Colour
  • Supports the video Bandwidth up to 10.8Gpbs
  • Connector Type A:DisplayPort male
  • Connector Type B:HDMI Female
Product Line
Cables Direct
