Your basket is empty
Cables Direct Digital Audio Cable (optical) - TOSLINK (M) to TOSLINK (M) - 2m - Fibre Optic
Quicklinx: 9J0PWS00 Mfr#: 4OPT-102
Type: Toslink
Length: 2m
Hurry, only 3 left in stock!
£3.99 ex VAT
£4.78 inc VAT
Express delivery Delivered on Tuesday
TOSLINK or Optical Cable is a fiber optic connection system. Most commonly used with audio equipment (via a "digital optical" socket,) where it carries a digital audio stream from devices such as CD, DVD, Blu-Ray players and modern video game consoles, to an AV receiver such as surround sound system that can decode the stream of audio and output it through a set of loudspeakers. Since TOSLINK uses fibre-optic cable, it is free from distortion caused by electrical or magnetic interference that an electrical cable would incur.
The result is an audio signal that is purer, as well as truer to the original recording. Gold plating is used on the connectors for its anti-corrosive properties.
Key Features:
  • Cable: Optical Fibre
  • Outside Diameter: 5mm
  • Length: 200cm
  • Colour: Black
  • Warranty: 1 year
  • Packaging: Polybag (OEM)
Cables Direct digital audio cable (optical) - 2 m
Cable
Digital audio cable (optical)
Fibre optic
Length
2 m
Connector
TOSLINK - male
Connector (Second End)
TOSLINK - male
Corrosion-resistant connectors
1 year warranty
Cable Type
Fibre optic
Length
2 m
Plated Connector
Gold
Connector
TOSLINK - male
TOSLINK - male
Limited warranty - 1 year
Type: Toslink
Length: 2m
Brand: Cables Direct
Price Range Ex VAT: 0 - 50
