Cables Direct Cat 6 Ethernet Network Cables Green 1m
Quicklinx: 9MHSWS00 Mfr#: 99LHT6-601G
Category 6 cable, commonly referred to as Cat-6, is a cable standard for Gigabit Ethernet and other network protocols that are backward compatible with the Category 5/5e and Category 3 cable standards. Compared with Cat-5 and Cat-5e, Cat-6 features more stringent specifications for crosstalk and system noise. The cable standard provides performance of up to 250 MHz.
Cables Direct patch cable - 1 m - green
Patch cable - CAT 6
Unshielded twisted pair (UTP)
Wires per Cable
8 wires
Halogen-free, molded, snagless, CCA stranded cores
Length
1 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Green
1-year warranty
Network Cable Type
Patch cable - CAT 6
Jacket Material
Low Smoke Zero Halogen (LSZH)
American Wire Gauge (AWG)
24
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Length
1 m
Green
Connector
RJ-45 - male
RJ-45 - male
1-year warranty
