Cables Direct Best Value Wall Socket with built in 2 x USB Charging Ports
CHARGE / POWER 2X USB DEVICES + ELECTRICALS FROM 1 DOUBLE WALL PLATE!
Quicklinx: 9Q7YWS00 Mfr#: UT-86USB
This device must be installed by a competent person, in accordance with the current edition of the IET Wiring Regulations (BS7671) & Building Regulations.
Please read these instructions carefully before commencing with installation. Failure to install correctly will negate the product warranty.
The Dual Power Socket with Dual USB Outlet allows you to charge / power 2x USB devices and 2 other electrical items from one double wall plate.
The USB charging sockets are compatible with items such as smart phones, tablets and other devices that require charging via a USB port. The USB charging sockets have a total output of 2 amps (combined); if the current exceeds this it will automatically shut down to protect your device.
This dual switched socket will fit any standard dual 25mm deep wall box.
Instructions
  • Firstly, ensure you isolate the mains power supply and remove the fuse in the fuse box or switch off the circuit breaker in the consumer unit.
  • Following the diagram over-leaf pass the cable through the entry holes and connect to the appropriate terminal.
  • If an Earth loop connection is required, use the additional earth terminal block located in the back box.
  • Re-connect the mains supply when the installation is correctly completed.
  • Before use we recommend that a socket test is carried out.
  • DO NOT MEGGER TEST - this will damage the USB charging circuit.
  • The USB charger will have a minimal quiescent current (should be no greater than 5mA). When a device is plugged it will determine how many amps the product needs and output at that rate.
  • Working voltage: 13A, 250V
  • Working temperature -15 to 40 C
  • USB Output: 2A, 5V
  • UK 3 pin socket output: 13A, 250V
  • Fits any standard back box (minimum depth of 25mm)
Safety Information
  • We recommend using a competent person for installation.
  • Only suitable for indoor installations.
  • Before carrying out any electrical work, isolate the mains power supply & refer to the fitting instructions.
  • For safe installation & connection ensure that the earth is connected.
  • Wire/wiring colours are in accordance with the current IET Wiring Regulations
Product Details
  • Weight 193g
  • Height 85mm
  • Width 145mm
  • Depth 25mm
