USB 3.0 is the new standard for super speed Universal Serial Bus, USB 3.0 can support speeds up to 5Gbps. Our USB 3.0 cables are built to the USB 3.0 specification. With USB 3.0 being in it’s early stages, speeds may vary due to hardware restrictions.
- Cables Direct USB cable - 75 cm
- USB cable
- Technology
- Shielded
- Drain wire
- Length
- 75 cm
- Connector
- 10 pin Micro-USB Type B - male
- Connector (Second End)
- 9 pin USB Type A - male
- USB / USB 2.0 / USB 3.0
- Black
- 1 year warranty
- USB cable
- Technology
- Shielded
- American Wire Gauge (AWG)
- 30
- Plated Connector
- Nickel
- Drain wire
- Length
- 75 cm
- Black
- Connector
- 1 year warranty
