The NLWL-CAB05 wireless antenna extension cable is the perfect solution to positioning your Antenna for the best signal without moving your computer or router. The NLWL-CAB05 creates an extension of 5 meters. The cable is a thin flexible mini coax of 26 AWG, a braided shield and brass reverse SMA male-female connector.
- NEWlink antenna extension cable - 5 m
- Cable
- Antenna extension cable
- Technology
- Coaxial
- American Wire Gauge (AWG)
- 26
- Length
- 5 m
- Connector
- R-SMA - male
- Connector (Second End)
- R-SMA - female
- Cable Type
- Technology
- Coaxial
- 26
- Shielding Material
- Braid
- Impedance
- 50 Ohm
- Length
- 5 m
- Connector
- R-SMA - male
- R-SMA - female
