Your basket is empty
Cables Direct 50cm CAT 6 UTP PVC Injected Moulded Cable - Yellow B/Q 250
Quicklinx: B78SWS00 Mfr#: ERT-600Y
Category 6 cable, commonly referred to as Cat-6, is a cable standard for Gigabit Ethernet and other network protocols that are backward compatible with the Category 5/5e and Category 3 cable standards. Compared with Cat-5 and Cat-5e, Cat-6 features more stringent specifications for crosstalk and system noise. The cable standard provides performance of up to 250 MHz.
  • 0.5 Mtr
  • Yellow
  • UTP (Unshielded Twisted Pair)
  • CAT 6
  • Moulded
  • 24AWG x 4P
  • Patch Type CM (UL) CMH E164469-F3
  • ISO/IEC 11801 & EN 50288 & TIA/EIA-563-B.2-1 ETL/3P VERIFIED
Cables Direct patch cable - 50 cm - yellow
Patch cable - CAT 6
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Molded
Length
50 cm
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Yellow
Network Cable Type
Patch cable - CAT 6
Wiring Scheme
T568B
American Wire Gauge (AWG)
24
Molded
Length
50 cm
Yellow
Connector
RJ-45 - male
RJ-45 - male
