Cables Direct 4 Metre CAT 6 UTP PVC INJ Moulded Cable Grey B/Q 100
Quicklinx: CGHBWS00 Mfr#: ERT-604
Category 6 cable, commonly referred to as Cat-6, is a cable standard for Gigabit Ethernet and other network protocols that are backward compatible with the Category 5/5e and Category 3 cable standards. Compared with Cat-5 and Cat-5e, Cat-6 features more stringent specifications for crosstalk and system noise. The cable standard provides performance of up to 250MHz.
Cables Direct patch cable - 4 m - grey
Patch cable - CAT 6
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Molded
Length
4 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Grey
Network Cable Type
Patch cable - CAT 6
Wiring Scheme
T568B
American Wire Gauge (AWG)
24
Molded
Length
4 m
Grey
Connector
RJ-45 - male
RJ-45 - male
