Your basket is empty
Cables Direct 3m Black DisplayPort M-M Gold with Locking Connectors V1.2 - B/Q 50
Clearance!
Clearance
Last Few Remaining
Limited Time Offer
Quicklinx: C8B3WS00 Mfr#: CDLDP-003LOCK
DisplayPort is a 20 pin connector similar to HDMI but designed to replace DVI/VGA. The standard was put forward by VESA to define a new royalty free audio/video connection.
DisplayPort is very simple to use and makes connecting your PC to your DisplayPort enabled display very easy. Our DisplayPort cables are black with gold flashed locking connectors to reduce disconnection due to cable strain.
Cables Direct DisplayPort cable - 3 m
DisplayPort cable
Lockable connector
Length
3 m
Connector
DisplayPort - male
Connector (Second End)
DisplayPort - male
1 year warranty
DisplayPort cable
American Wire Gauge (AWG)
28
Plated Connector
Gold
Lockable connector
Length
3 m
Connector
20 pin DisplayPort - male
1 year warranty
