Product
Cables Direct 36CM USB A M - 2 X PS/2 F ADAPTOR CABLE
Quicklinx: 64D2WS00 Mfr#: NLUSB-004
The concept of Best Value is to offer customers the best value product, sourced from a variety of manufacturers all over the world, in any given category, at any point in time. The products selected for our Best Value range are carefully evaluated in terms of price, performance and manufacturing quality before they make it onto our website. Although certainly a 'value' brand, Best Value products are never inferior quality... just superb value for money.
Our USB PS/2 Adaptor can be used on Desktop or Laptop systems, and allows users to connect a PS/2 Mouse and / or Keyboard to any unused USB port, enabling other devices to occupy the existing PS/2 port(s). Lightweight and Easy to use, this product is compatible for use with KVM Switches, PCs, MACs, Sun Microsystems and a vast range of Operating Systems.
  • Supports UHCI (Universal Host Controller Interface) and OHCI (Open Host Controller Interface)
  • Converts a PS/2 Keyboard and PS/2 Mouse to USB
  • Compliant with USB 1.1 and 1.0 specifications
  • Supports Microsoft IntelliMouse and Compatibles
  • Compatible for use with KVM Switches
  • Sun Microsystems Compatible
  • Easy to install, No software needed
  • No power adaptor needed
Specification
  • Total Length 35.5 cm
  • 1.5 Mbps Transfer Rate
  • USB Bus powered
  • Type A USB Plug
  • 1x Green PS/2 Female for Mouse Use
  • 1x Purple PS/2 Female for Keyboard Use
  • One Free USB Port
  • Any of the Following Operating Systems:-
  • Windows 98/SE, Millennium Edition, 2000, XP
  • Netware 4.11 / 5.0
  • HP Unix
  • Linux
  • MAC OS 8.6 or Higher
  • Sun Microsystems.
Product Line
Cables Direct
