Our range on Super VGA cables are constructed using UL2919 approved 28awg triple mini coaxial and 4x 28awg conductor cables, this allows them to be used for extended distances. Triple shielded with copper braid, foil and drain wire. Our cables are designed for standard monitors and widescreen LCD’s that require DDC cable.
- Cables Direct VGA cable - 25 m
- VGA cable
- Technology
- Triple shielded coaxial
- Molded, drain wire
- Length
- 25 m
- Connector
- HD-15 (VGA) - male
- Connector (Second End)
- UL 2919
- Black
- VGA cable
- Technology
- Shielding Material
- Foil with copper braid
- American Wire Gauge (AWG)
- 28
- Length
- 25 m
- Black
- Connector
- 15 pin HD D-Sub (HD-15) - male
- UL 2919
