Product
Cables Direct 25m CAT6A SSTP-LSOH Patch Cable Snagless Blue - B/Q 20
Quicklinx: C89ZWS00 Mfr#: ART-125B
Length: 25m
Colour: Blue
More than 50 in stock
£17.58 ex VAT
£21.09 inc VAT
Standard delivery Delivered within 3-5 working days
Category 6A Ethernet cable, commonly referred to as Cat6A, is a cable standard for 10 Gigabit Ethernet. The cable standard provides performance of up to 600MHz and is suitable for 10BASE-T, 100BASE-TX (Fast Ethernet), 1000BASE-T / 1000BASE-TX (Gigabit Ethernet) and 10GBASE-T (10 Gigabit Ethernet). It is backwards compatible with previous standards such as Cat6, Cat5e and Cat5.
  • LSZH: low Smoke Zero Halogen cable reduces the amount of toxic and corrosive gas emitted during a fire.
  • Supports 10 Gigabit Ethernet / 10GBASE-T: 10 Times faster than Gigabit Ethernet, 10GE (also called 10GbE or 10 GigE) supports a data rate of 10Gbits/s (billion bits per second).
  • S/FTP (or S/STP): Screened and Foil (Shielded) Twisted Pair. Each individual pair is screened by foil and features an overall outer sheath. This shielding protects the cable from EMI (Electro-Magnetic Interference).
  • Snagless Connectors: The connectors feature a "bubble" which protects the locking clip on the RJ45 from damage or being snapped off during transport or installation.
  • Flush Moulded Strain Relief: The flush moulded design allows the patch cables to be installed side by side in high-density network switches. The strain relief allows the cables to move without damaging the cable or breaking away from the connector while it is plugged in a device
  • This product has been tested and found to comply with the applicable electrical transmission characteristics specified in: ISO/IEC 11801 ED.2 and ANSI/TIA-568-C.2
  • IEC 60332-1-2, RoHS Compliant and 3P Verified
Cables Direct patch cable - 25 m - blue
Patch cable - CAT 6a
Shielded foiled twisted pair (SFTP)
Wires per Cable
8 wires
Halogen-free, molded, snagless, strain relief
Length
25 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Blue
Network Cable Type
Jacket Material
Low Smoke Zero Halogen (LSZH)
American Wire Gauge (AWG)
26
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Length
25 m
Blue
Connector
RJ-45 - male
RJ-45 - male
RoHS, ISO/IEC 11801, TIA/EIA-568-C.2, 3P, IEC 60332-1-2 - up to 600 MHz
Length: 25m
Colour: Blue
Brand: Cables Direct
Price Range Ex VAT: 0 - 50
