Your basket is empty
Cables Direct 1m CAT 6 UTP PVC Injected Moulded Cable - Red B/Q 250
Quicklinx: 9PHRWS00 Mfr#: ERT-601R
Category 6 cable, commonly referred to as Cat-6, is a cable standard for Gigabit Ethernet and other network protocols that are backward compatible with the Category 5/5e and Category 3 cable standards. Compared with Cat-5 and Cat-5e, Cat-6 features more stringent specifications for crosstalk and system noise. The cable standard provides performance of up to 250 MHz.
Cables Direct patch cable - 1 m - red
Patch cable - CAT 6
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Molded
Length
1 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Red
Network Cable Type
Patch cable - CAT 6
Wiring Scheme
T568B
American Wire Gauge (AWG)
24
Molded
Length
1 m
Red
Connector
RJ-45 - male
RJ-45 - male
