Cables Direct 15cm Leaded USB Type-C to HDMI & USB Adapter
Quicklinx: CPCJWS00 Mfr#: USB3C-HDMIUSB-WPD
More than 50 in stock
£19.07 ex VAT
£22.88 inc VAT
The USB3C-HDMIUSB-WPD is a USB-C to USB 3.0, HDMI and USB-C charging port hub. The USB 3.0 port allows you to connect a USB device to the host computer or another hub. The USB-C female port can charge the host computer and supply power for the adapter at the same time. The HDMI port allows you to connect an extra monitor so that you can watch videos or slideshows on the big screen.
It also features a USB-C female port so you can charge for the host computer and supply power for the adapter simultaneously. It can work on Macbook’s or Google’s new Chromebook Pixel as well as other USB-C supported devices.
Cables Direct - docking station
Docking station
Docking Interface
USB-C
1-year warranty
Docking station
1 x USB-C - 24 pin USB-C , 1 x audio / video - 19 pin HDMI Type A , 1 x SuperSpeed USB 3.0 - 9 pin USB Type A
Limited warranty - 1 year
Brand: Cables Direct
Price Range Ex VAT: 0 - 50
