Cables Direct 15cm Leaded USB Type-C to DVI Adapter
Quicklinx: CPCMWS00 Mfr#: USB3C-DVICAB-WPD
The USB3C-DVICAB-WPD is a USB-C to DVI Adapter with a USB-C charging port. It is designed to transmit signals from USB-C computers to DVI monitors so that you can watch videos or slideshows on the big screen. It also features a USB-C female port so you can charge for the host computer and supply power for the adapter simultaneously. It can work on Macbook’s or Google’s new Chromebook Pixel as well as other USB-C supported devices.
Cables Direct - external video adapter
External video adapter
Bus Type
USB-C
Max Resolution
1920 x 1080
DVI , USB-C (power only)
1-year warranty
Bus Type
USB-C
Max Resolution
1920 x 1080 at 60 Hz
USB powered, HDCP
1 x USB-C cable - 15 cm
DisplayPort 1.2
Limited warranty - 1 year
