The USB3C-DVICAB-WPD is a USB-C to DVI Adapter with a USB-C charging port. It is designed to transmit signals from USB-C computers to DVI monitors so that you can watch videos or slideshows on the big screen. It also features a USB-C female port so you can charge for the host computer and supply power for the adapter simultaneously. It can work on Macbook’s or Google’s new Chromebook Pixel as well as other USB-C supported devices.
- Cables Direct - external video adapter
- External video adapter
- Bus Type
- USB-C
- Max Resolution
- 1920 x 1080
- Interfaces Details
- DVI , USB-C (power only)
- 1-year warranty
- Bus Type
- USB-C
- Max Resolution
- 1920 x 1080 at 60 Hz
- USB powered, HDCP
- Cables Included
- 1 x USB-C cable - 15 cm
- DisplayPort 1.2
- Limited warranty - 1 year
