Product
Cables Direct 10Mtr Reverse SMA M-F Extension Cable B/Q
Quicklinx: D13QWS00 Mfr#: NLWL-CAB10
The NLWL-CAB10 wireless antenna extension cable is the perfect solution to positioning your Antenna for the best signal without moving your computer or router. The NLWL-CAB10 creates an extension of 10 meters. The cable is a thin flexible mini coax of 26 AWG, a braided shield and brass reverse SMA male-female connector.
NEWlink antenna extension cable - 10 m
Cable
Antenna extension cable
Coaxial
American Wire Gauge (AWG)
26
Length
10 m
Connector
R-SMA - male
Connector (Second End)
R-SMA - female
Cable Type
Coaxial
26
Shielding Material
Braid
Impedance
50 Ohm
Length
10 m
Connector
R-SMA - male
R-SMA - female
