Cables Direct 10m DVI-D Single Link M-M Cable
Quicklinx: CCHMWS00 Mfr#: CDL-DV06-10M
Length: 10m
37 in stock
£11.45 ex VAT
£13.74 inc VAT
This DVI cable is for digital connections and abbreviated as DVI-D. For use with equipment that uses either DVI-D connectors, if used with a DVI-I connector only the digital signal will pass through. Please note this will not work with analogue equipment that uses DVI-A.
Cables Direct DVI cable - 10 m
DVI cable - single link
Ferrite filter
Length
10 m
Connector
DVI-D - male
Connector (Second End)
DVI-D - male
1 year warranty
DVI cable
TMDS Links
Single link
Plated Connector
Gold
Ferrite filter
Length
10 m
Connector
18+1 pin digital DVI (Single-Link) - male
1 year warranty
Length: 10m
Brand: Cables Direct
Price Range Ex VAT: 0 - 50
