Product
Cables Direct 0.5M Network 6 LSOH Patch Lead - Moulded - Green - B/Q 250
Clearance!
Clearance
Quicklinx: B7RGWS00 Mfr#: 99LHT6-600G
Length: 50cm
Colour: Green
More than 50 in stock
£0.44 ex VAT
£0.52 inc VAT
Category 6 cable, commonly referred to as Cat-6, is a cable standard for Gigabit Ethernet and other network protocols that are backward compatible with the Category 5/5e and Category 3 cable standards. Compared with Cat-5 and Cat-5e, Cat-6 features more stringent specifications for crosstalk and system noise. The cable standard provides performance of up to 250 MHz.
Cables Direct patch cable - 50 cm - green
Patch cable - CAT 6
Halogen-free, molded
Length
50 cm
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Green
Network Cable Type
Patch cable - CAT 6
Jacket Material
Low Smoke Zero Halogen (LSZH)
Length
50 cm
Green
Connector
RJ-45 - male
RJ-45 - male
Length: 50cm
Colour: Green
Brand: Cables Direct
Price Range Ex VAT: 0 - 50
