Category 6 cable, commonly referred to as Cat-6, is a cable standard for Gigabit Ethernet and other network protocols that are backward compatible with the Category 5/5e and Category 3 cable standards. Compared with Cat-5 and Cat-5e, Cat-6 features more stringent specifications for crosstalk and system noise. The cable standard provides performance of up to 250 MHz.
- Cables Direct patch cable - 50 cm - pink
- Patch cable - CAT 6
- Technology
- Wiring Scheme
- T568B
- Molded
- Length
- 50 cm
- Connector
- RJ-45 - male
- Connector (Second End)
- RJ-45 - male
- Pink
- Network Cable Type
- Technology
- Wiring Scheme
- T568B
- American Wire Gauge (AWG)
- 24
- Molded
- Length
- 50 cm
- Pink
- Connector
- RJ-45 - male
- RJ-45 - male
