Product
C2G XFP-10G-S 10GBase-SR XFP Transceiver
Quicklinx: CJ99WS00 Mfr#: 89120
£175.84 ex VAT
£211.00 inc VAT
This Juniper Networks XFP-10G-S compatible XFP transceiver provides 10GBase-SR throughput up to 300m over multi-mode Fibre (MMF) at a wavelength of 850nm using a LC connector. Digital optical monitoring (DOM) support is also present to allow access to real-time operating parameters. Our transceiver is guaranteed to be 100% compatible with the equivalent Juniper Networks transceiver. This easy to install, hot swappable transceiver has been programmed, uniquely serialized and data-traffic and application tested to ensure that it will initialize and perform identically. It is built to meet or exceed the specifications of Juniper Networks, as well as to comply with multi-source agreement (MSA) standards to ensure seamless network integration.
  • Colour
    Silver
  • Connector 1
    XFP Male
  • Connector 2
    LC Female
  • Warranty
    Lifetime
C2G - XFP transceiver module - 10 GigE
XFP transceiver module - LC multi-mode
Plug-in module
Cabling Type
10GBase-SR
Data Transfer Rate
10 Gbps
Optical Wave Length
850 nm
10 GigE
Max Transfer Distance
300 m
Juniper XFP-10G-S
1.27 cm x 6.35 cm x 0.76 cm
90.7 g
Juniper M-series M120, M120-H, M120-L
Plug-in module
Silver
Wired
Cabling Type
10GBase-SR
10 GigE
Data Transfer Rate
10 Gbps
Optical Wave Length
850 nm
300 m
Digital Optical Monitoring (DOM) support
1 x Ethernet 10GBase-SR - LC multi-mode female x 2
MSA
Juniper XFP-10G-S
1.27 cm
6.35 cm
0.76 cm
90.7 g
Limited warranty - lifetime
Brand: C2G
Price Range Ex VAT: 150 - 300
