Product
C2G XENPAK-10GB-SR 10GBase-SR Transceiver
Quicklinx: CJ9RWS00 Mfr#: 89132
£289.45 ex VAT
£347.34 inc VAT
This Cisco XENPAK-10GB-SR compatible XENPAK transceiver provides 10GBase-SR throughput up to 300m over multi-mode Fibre (MMF) at a wavelength of 850nm using a SC connector. Our transceiver is guaranteed to be 100% compatible with the equivalent Cisco transceiver. This easy to install, hot swappable transceiver has been programmed, uniquely serialized and data-traffic and application tested to ensure that it will initialize and perform identically. It is built to meet or exceed the specifications of Cisco, as well as to comply with multi-source agreement (MSA) standards to ensure seamless network integration.
  • Colour
    Silver
  • Connector 1
    XENPAK Male
  • Connector 2
    SC Female
  • Warranty
    Lifetime
C2G - XENPAK transceiver module - 10 GigE
XENPAK transceiver module - SC multi-mode
Plug-in module
Cabling Type
10GBase-SR
Data Transfer Rate
10 Gbps
Optical Wave Length
850 nm
10 GigE
Max Transfer Distance
300 m
3.56 cm x 12.2 cm x 1.27 cm
336 g
P/N: WS-SUP32-10GE-3B, WS-SUP32-10GE-3B=, WS-SUP32-10GE-3B-RF, WS-X6704-10GE, WS-X6704-10GE=, WS-X6704-10GE-RF
Plug-in module
Silver
Wired
Cabling Type
10GBase-SR
10 GigE
Data Transfer Rate
10 Gbps
Optical Wave Length
850 nm
300 m
1 x Ethernet 10GBase-SR - SC multi-mode female x 2
MSA
3.56 cm
12.2 cm
1.27 cm
336 g
Limited warranty - lifetime
Brand: C2G
Price Range Ex VAT: 150 - 300
