Product
C2G WS-G5483 1000Base-TX GBIC Transceiver
Quicklinx: CJ8BWS00 Mfr#: 89115
£54.61 ex VAT
£65.53 inc VAT
This Cisco WS-G5483 compatible GBIC transceiver provides 1000Base-TX throughput up to 100m over a copper connection using a RJ-45 connector. Our transceiver is guaranteed to be 100% compatible with the equivalent Cisco transceiver. This easy to install, hot swappable transceiver has been programmed, uniquely serialized and data-traffic and application tested to ensure that it will initialize and perform identically. It is built to meet or exceed the specifications of Cisco, as well as to comply with multi-source agreement (MSA) standards to ensure seamless network integration.
  • Colour
    Silver
  • Connector 1
    GBIC Male
  • Connector 2
    RJ-45 Female
  • Warranty
    Lifetime
C2G - GBIC transceiver module - GigE
GBIC transceiver module - RJ-45
Plug-in module
Cabling Type
1000Base-TX
Data Transfer Rate
1 Gbps
GigE
Max Transfer Distance
100 m
Cisco WS-G5483
3.05 cm x 6.6 cm x 1.02 cm
27.2 g
Cisco Catalyst 2912, 2924, 2948, 2950G-12, 2950G-24, 2950G-48, 2980, 3508, 3512, 3524, 3548, 3550-12, 3550-24, 3550-48, 4500, 4912; Supervisor Engine 1A 2GE, 2-MSFC2, 2-PFC2, II, II-Plus, IV, V, V-10
Plug-in module
Silver
Wired
Cabling Type
1000Base-TX
GigE
Data Transfer Rate
1 Gbps
100 m
1 x Ethernet 1000Base-TX - RJ-45 female
MSA
Cisco WS-G5483
3.05 cm
6.6 cm
1.02 cm
27.2 g
Limited warranty - lifetime
Cisco Catalyst 2912MF, 2912MF-XL, 2912MF-XL Enterprise Edition, 2924M, 2924M-XL, 2924M-XL DC, 2924M-XL Enterprise Edition, 2948G, 2948G-GE-TX Gigabit Ethernet Switch, 2948G-L3, 2950G-12, 2950G-24, 2950G-24-EI, 2950G-48, 2950G-48-EI, 2980G, 2980G-A, 3508G XL Enterprise Edition, 3512 XL Enterprise Edition, 3512G XL Enterprise Edition, 3512XL Standard Edition, 3524-PWR XL Enterprise Edition, 3524XL Enterprise Edition, 3548XL Enterprise Edition, 3550-12G, 3550-12T, 3550-24 EMI, 3550-24 PWR EMI, 3550-24 PWR SMI, 3550-24 SMI, 3550-48 EMI, 3550-48 SMI, 4500 Series Supervisor Engine V-10GE, 4912G , Cisco Supervisor Engine 1A 2GE, 1A 2GE Plus, 1A 2GE Plus MSFC & PFC, 1A 2GE Plus PFC, 2-MSFC2, 2-PFC2, II, II-Plus, IV, V, V-10GE
Brand: C2G
Price Range Ex VAT: 50 - 100
