C2G WIRELESS AV FOR HDMI 2 RECEIVER KIT TAA
Quicklinx: FBGMWS00 Mfr#: 89512
£348.72 ex VAT
£418.46 inc VAT
Always start a meeting or class on time with the Wireless A/V for HDMI devices kit. This plug and play system allows A/V signals from a laptop, tablet, or Blu-ray player to wirelessly connect to two HDMI projectors or HDTVs located up to 30 metres (100 ft) away. Straightforward install There is no need for cables to be run under the floor, through the ceiling, or up a wall. Mount the receivers near the displays and the transmitter near the presenter, then make the connections for HDMI and power on both the transmitter and receivers. This do-it-yourself solution includes all the components required for the setup and does not require an experienced A/V installer. Just plug an HDMI cable into your laptop from the transmitter, and you are ready to present. This kit offers true plug and play operation, allowing any presenter to step up and start a meeting with no lost time. There is no software to install or update, so there is no need to request permissions from IT or wait for drivers to download. Effortless huddle space connectivity Just bring your own device to the huddle space and plug in. This simple, one connection solution allows for quick transition from one user to another – encouraging productivity, inspiration, and teamwork while presenting ideas. Any room can be retrofitted to be a huddle space, as the secure wireless transmission of A/V signal does not require new cables or existing cable infrastructure. De-cluttered conference room Set up a conference room without limitations using this wireless system. The displays do not have to be limited to where wire runs have been located. Place displays anywhere within 30 metres (100 feet) of the transmitter to achieve the optimal setup for any conference room. Trouble free classroom setup Setting up A/V equipment in a classroom often requires running cables in wall, this type of install requires specially rated cables and professional installation. With the Wireless AV for HDMI solution there is no need to run these costly wires. The straightforward installation takes almost no time to setup and the simplified operation ensures all staff members can use it without training. Note: The transmitter and receivers do not require line-of-sight to function. However to achieve the 30 metres (100ft) maximum range, reduce or eliminate the number of obstacles between the transmitter and receivers.
  • Colour
  • Warranty
    3 Years
  • Connector 1
    (2) HDMI Female, (2) USB Micro-B Female
  • Connector 2
    (1) HDMI Female, (1) USB Micro-B Female
C2G Wireless AV for HDMI Devices - with 2 Receiver Kit - wireless video/audio extender - HDMI
Wireless video/audio extender
External
Frequency Band
5 GHz
HDMI
Max Transfer Distance
30 m
3-year warranty
External
Wireless
HDMI
Frequency Band
5 GHz
Max Resolution
1080p @ 60 Hz
30 m
USB powered, Intel Wireless Display (WiDi), 1T2R MIMO technology, DTCP-IP support
IEEE 802.11n
2 x HDMI (output) - 19 pin HDMI Type A female , 1 x HDMI (input) - 19 pin HDMI Type A female , 3 x micro-USB (power) - Type B female
Double sided tape
3 x HDMI cable , USB power cable
HDCP 2.2, HDCP 2.3
External power adapter
Installed Qty
3
Limited warranty - 3 years
Brand: C2G
Price Range Ex VAT: 300 - 500
