TRULinkā¢ VGA to Composite PC-TV Video Adapter
Convert your PC's VGA signal to Composite to allow connection to a TV
The Cables To Go PC-TV adapter device allows you to convert your VGA signal from a computer to a composite out video so you can connect your PC, Mac or other VGA devices to your TV or projector. This is useful when connecting your computer to an older TV or projector that doesn't support VGA, for large screen viewing. This device also comes with VGA and S-Video output ports to allow viewing on multiple displays which can support these signals. The converter kit comes with a USB power adapter so it can draw power from your computer instead of needing a dedicated outlet. This device's small footprint makes it easy for travel or to fit in tight spaces. The menu options allow for customization of display adjustment settings.
Applications
- Perfect for home or office VGA to Composite adapter applications, including:
- Media Centers
- Conference Rooms
- Digital Signage
- Conveniently placed front buttons to help navigate menu options
- USB power adapter - no need to plug into an outlet
- Three different outputs to allow viewing on three separate displays simultaneously
Input
- (1) VGA 8-Pin Female (adapter cable included)
- (1) USB Power Adapter
Output
- (1) Composite Video Female
- (1) VGA HD-15 Female
(1) S-Video Female
No software required
- Free technical support & 1yr warranty
- C2G VGA to Composite PC-TV Video Adapter - external video adapter - black
- External video adapter
- Interfaces Details
- VGA input , S-video , VGA , Composite video input
- Enclosure Colour
- Black
- 1-year warranty
Video Output
- Supported Display Graphics
- XGA (1024x768)
- Cables Included
- 1 x USB cable , 1 x composite video cable , 1 x VGA cable
- RoHS
- 422 g
- Enclosure Colour
- Black
- Limited warranty - 1 year
