Product
C2G Velocity™ DVI-D™ Male to HDMI® Female Inline Adapter
Clearance!
Clearance
Quicklinx: 8GZKWS00 Mfr#: 80347
£5.00 ex VAT
£6.00 inc VAT
Use this adapter to provide a pure digital, high-definition video connection! You'll see the purity of the original signal with absolutely no picture degradation! Fully tested and absolutely guaranteed. Gold-plated contacts deliver worry-free performance, and make this adapter an ideal choice to connect digital source components to DVI-equipped display devices! Ideal for satellite, DVD player, HDTV, plasma, LCD and DLP applications. Don't compromise your high-definition video signal; use the right interconnects!
C2G Velocity Inline Adapter - video adapter - HDMI / DVI
Cable
Video adapter - HDMI / DVI
Connector
DVI-D - male
Connector (Second End)
HDMI - female
Thumbscrews
Cable Type
Video adapter
Interface Supported
HDMI / DVI
Plated Connector
Gold
Thumbscrews
Connector
18+1 pin digital DVI (Single-Link) - male
19 pin HDMI Type A - female
Limited warranty - lifetime
Brand: C2G
Price Range Ex VAT: 0 - 50
