The DVI-D male to HDMI female Inline Adapter provides a pure digital, high definition video connection, allowing you can connect your digital source device to a DVI-equipped display device with absolutely no reduction in picture quality. This Adapter supports up to a 1080p resolution and is compatible with satellite, DVD player, HDTV, Plasma, LCD and DLP applications. Additionally, gold-plated contacts deliver worry-free performance.
Black -
Warranty
Lifetime -
Connector 1
(1) DVI-D Single Link Male -
Connector 2
(1) HDMI (Type A) Port
- C2G Velocity Inline Adapter - video adapter
- Cable
- Video adapter - HDMI / DVI
- Black
- Connector
- DVI-D - male
- Connector (Second End)
- HDMI - female
- Thumbscrews
- Limited lifetime warranty
- Cable Type
- Video adapter
- Interface Supported
- HDMI / DVI
- Plated Connector
- Gold
- Thumbscrews
- Black
- Connector
- 18+1 pin digital DVI (Single-Link) - male
- 19 pin HDMI Type A - female
- Limited warranty - lifetime
