The DVI-D female to HDMI male Inline Adapter provides a pure digital, high definition video connection, allowing you can connect your digital source device to a HDMI-equipped display device with absolutely no reduction in picture quality. This Adapter supports up to a 1080p resolution and is compatible with satellite, DVD player, HDTV, Plasma, LCD and DLP applications. Additionally, gold-plated contacts deliver worry-free performance.
- C2G Velocity Inline Adapter - video adapter - HDMI / DVI
- Cable
- Video adapter - HDMI / DVI
- Black
- Connector
- DVI-D - female
- Connector (Second End)
- HDMI - male
- 1 year warranty
- Cable Type
- Video adapter
- Interface Supported
- HDMI / DVI
- Plated Connector
- Gold
- Black
- Connector
- 24+1 pin digital DVI - female
- 19 pin HDMI Type A - male
- Limited warranty - 1 year
