C2G USB to DVI Adapter Up To 2048 x 1152
Quicklinx: 8H1YWS00 Mfr#: 81636
The USB 2.0 to DVI Adapter provides the capability to extend your viewing options from a laptop or PC. Quickly and easily connect existing equipment to a VGA or DVI-I enabled monitor or projector using your computer's USB 2.0 port. Enjoy extended, mirrored or primary display modes and allow content to be shared across multiple displays which increases productivity while minimizing additional hardware investments. This plug-and-play solution includes an integrated driver that installs quickly and easily for immediate performance.
Once the driver is installed you can use up to six adapters connected simultaneously to a single computer to allow multi-display capability. High definition performance is achieved through resolutions up to 1920 x 1080 pixels and video streaming up to 1080p. With a compact form factor and rugged housing, this unit combines durability with functionality, ensuring optimal performance and results.
C2G USB 2.0 to DVI Adapter - external video adapter - grey
External video adapter
Bus Type
USB 2.0
Max Resolution
2048 x 1152
DVI-I (dual link) , USB 2.0
Enclosure Colour
Grey
1-year warranty
Bus Type
USB 2.0
Max Resolution
2048 x 1152
Microsoft Windows 2000 SP4, Microsoft Windows XP Professional SP2, Microsoft Windows XP Home Edition SP2, Microsoft Windows Vista (32/64 bits) SP1, Microsoft Windows XP Professional SP3, Microsoft Windows XP Home Edition SP3, Microsoft Windows 7 (32/64 bits)
Min Processor Type
1.2 GHz
Min RAM Size
512 MB
Additional Requirements
USB port (compatible with 2.0 specification)
1 x USB cable - 1 m
Software Included
Drivers & Utilities
RoHS
203 g
Enclosure Colour
Grey
Limited warranty - 1 year
