Your basket is empty
C2G USB Superbooster Extender Kit
Quicklinx: 7H7BWS00 Mfr#: 81621
Stock Status: Clearance
£26.53 ex VAT
£31.83 inc VAT
Express delivery Order within the next 19 hours for delivery on Monday
This USB Superbooster Extender Kit is a brilliant solution for long length USB limitations. Put your USB devices where you want them with Cables to Go's TruLink USB Superbooster. This pocket-sized device extends the distance of a USB device to a host computer up to 45 meters so you can place your USB camera, printer, web cam, keyboard/mouse extension, or any other USB device exactly where you want it! This booster is powerful yet simple, with no drivers to install or special software required, it's compatible with any computer that supports USB.
This Plug-and-Play device consists of a base unit and a remote unit connected together by a standard CAT5, CAT5e, CAT6 or CAT6a network cable. Simply connect your cables to your device; then connect to your computer and USB peripheral and you're up and running. Bus-powered, it requires no external power source. Instead, the Superbooster has internal DC power conditioning circuits to maintain the proper voltage to the remote device so no external power is required for either the base or remote units. It is compliant with USB specification 1.1.
Connector 1: (1) RJ45 Jack , (1) USB Type A Female
C2G USB Superbooster Extender Kit - USB extender - USB
USB extender
External
Data Transfer Rate
12 Mbps
USB
Max Transfer Distance
45 m
Microsoft Windows 2000/XP/Vista/7
1 year warranty
USB extender
External
Wired
USB
Data Transfer Rate
12 Mbps
45 m
USB powered
USB 1.1
1 x USB - Type A female
Plug and Play, RoHS
Limited warranty - 1 year
Resources
The following resources are available for the C2G USB Superbooster Extender Kit
Brand: C2G
Price Range Ex VAT: 0 - 50
