Product
C2G USB Charging Cable
Reduced Price - Whilst Stocks Last!
Quicklinx: 9Y4PWS00 Mfr#: 81708
Length: 46cm
Stock Status: Clearance
More than 50 in stock
£1.99 ex VAT
£2.38 inc VAT
Express delivery Order within the next 9 hours for delivery tomorrow
The USB charging cable is the ideal solution for charging a smartphone, tablet or other mobile device. The 30 gauge conductor construction provides the flexibility to connect in even the tightest of spaces. This flexibility and the compact size of this cable make it the ideal portable solution.
  • Connector 1
    (1) USB-A Male
  • Connector 2
    (1) USB Micro-B Male
  • Warranty
    Lifetime warranty
C2G USB Charging Cable - USB power cable - 46 cm
Cable
USB power cable
American Wire Gauge (AWG)
30
Length
46 cm
Connector
USB (power only) - male
Connector (Second End)
Micro-USB Type B (power only) - male
Cable Type
USB power cable
30
Length
46 cm
Plated Connector
Nickel
Connector
4 pin USB Type A (power only) - male
5 pin Micro-USB Type B (power only) - male
Limited warranty - lifetime
Length: 46cm
Brand: C2G
Price Range Ex VAT: 0 - 50
