The USB charging cable is the ideal solution for charging a smartphone, tablet or other mobile device. The 30 gauge conductor construction provides the flexibility to connect in even the tightest of spaces. This flexibility and the compact size of this cable make it the ideal portable solution.
- C2G USB Charging Cable - USB power cable - 46 cm
- Cable
- USB power cable
- American Wire Gauge (AWG)
- 30
- Length
- 46 cm
- Black
- Connector
- USB (power only) - male
- Connector (Second End)
- Micro-USB Type B (power only) - male
- Limited lifetime warranty
- Cable Type
- USB power cable
- 30
- Length
- 46 cm
- Plated Connector
- Nickel
- Black
- Connector
- 4 pin USB Type A (power only) - male
- 5 pin Micro-USB Type B (power only) - male
- Limited warranty - lifetime
