C2G USB C to VGA Video Adapter w/ Power Delivery - Black
Quicklinx: CHNFWS00 Mfr#: 80494
Colours:
£21.34 ex VAT
£25.60 inc VAT
The USB-C to VGA video adapter converter with power delivery is an ideal solution for connecting a device with a USB 3.1 Type C connector to an HDTV, projector, or other display with a VGA port to display video, whilst simultaneously charging the source device. This adapter supports resolutions up to 1920 x 1080 at 60 Hz, allowing it to deliver a high-quality video image to the connected display. With delivery of up to 60 W of charging power to the connected device, this video adapter converter offers a lightweight, portable and simple way to deliver video and stay charged up - whether you are out and about presenting, hot-desking or at home streaming movies. The USB-C connector has a robust design which allows for up to 10,000 connection cycles. Additionally, the USB-C connector has a symmetrical design which is identical on both sides, which means it does not matter if you plug it in upside-down or right-side-up - it will plug in the first time, every time, whilst preventing damage to the connector port. The colour-coded USB Type C connector allows this cable to be easily identified as a USB 2.0 cable and differentiated from other cables, which may support a different feature set.
  • Colour
  • Warranty
    3 Years
  • Connector A -1
    USB-C Male
  • Connector B -1
    VGA Female
  • Connector B -2
    USB-C Female
C2G USB C to VGA Video Adapter w/ Power Delivery - USB Type C to VGA Black - external video adapter - black
External video adapter
Bus Type
USB-C
Max Resolution
1920 x 1080
VGA (female connector) , USB-C (female connector) , USB-C (male connector)
Enclosure Colour
3-year warranty
Bus Type
USB-C
Max Resolution
Plug and Play
33 g
Enclosure Colour
Limited warranty - 3 years
50 °C
15 - 85% (non-condensing)
Brand: C2G
Price Range Ex VAT: 0 - 50
