C2G USB C to HDMI Adapter w/ Power Delivery - White
Quicklinx: CHNCWS00 Mfr#: 80493
Colours:
£19.52 ex VAT
£23.42 inc VAT
Experience 4K ULTRA HD displays and fast charging with this USB-C to HDMI Audio/Video adapter converter with power delivery which allows you to connect a device with a USB 3.1 Type C connector, such as a Chromebook, laptop or tablet, to an HDTV, projector or other HDMI-equipped display for audio and video, whilst simultaneously charging the source device. This adapter utilises the audio/video support built into the USB Type-C port to feed an audio/video signal to an HDTV or other HDMI display to achieve high-quality, 4K (ULTRA HD) video image. With delivery of up to 60 W of charging power to the connected device, this adapter converter offers a lightweight, portable and simple way to deliver video and stay charged up - whether you are out and about presenting, hot-desking or at home streaming movies. Additionally, the USB-C connector has a symmetrical design which is identical on both sides - it will plug in the first time, every time, whilst preventing damage to the connector port. The colour-coded USB Type C connector allows this cable to be easily identified as a USB 2.0 cable and differentiated from other cables, which may support a different feature set.
  • Colour
    White
  • Warranty
    3 Years
  • Connector A -1
    USB-C Male
  • Connector B -1
    HDMI Female
  • Connector B -2
    USB-C Female
C2G USB C to HDMI Audio/Video Adapter w/ Power Delivery - USB Type C to HDMI White - external video adapter - white
External video adapter
Bus Type
USB-C
Max Resolution
3840 x 2160
HDMI (female connector) , USB-C (female connector) , USB-C (male connector)
Enclosure Colour
White
3-year warranty
Bus Type
USB-C
Max Resolution
3840 x 2160 at 30 Hz
Plug and Play
31 g
Enclosure Colour
White
Limited warranty - 3 years
50 °C
15 - 85% (non-condensing)
Brand: C2G
Price Range Ex VAT: 0 - 50
