C2G USB C to Gigabit Ethernet Network Adapter
Quicklinx: CH34WS00 Mfr#: 89052
Wired / Wireless: Wired
Protocol: Ethernet, Fast Ethernet, Gigabit Ethernet
Compatibility: Mac, PC
Type: Network adapter
Hurry, only 1 left in stock!
£27.31 ex VAT
£32.77 inc VAT
The USB-C to Gigabit Ethernet Network Adapter is an ideal solution for converting an existing USB Type-C port on your laptop, Chromebook, tablet or other USB-C enabled device to a RJ45 Gigabit Ethernet port for a wired network connection to the Internet. This adapter utilises the high bandwidth of the USB-C port to support true Gigabit Ethernet speeds. This flexible solution requires no external power supply - simply connect the adapter to an available USB-C port, and connect a Cat5 cable from the adapter to an RJ45 Network port for a straightforward installation. Additionally, the USB-C connector has a symmetrical design which is identical on both sides, which means it does not matter if you plug it in upside-down or right-side-up - it will plug in first time, every time, whilst preventing damage to the port. With speeds up to 1000Mbps, file transfer between computers is fast and easy, even with very large files or large amounts of multimedia data. The adapter is a great solution for more modern computers that do not provide a wired Ethernet port or have a damaged Ethernet port.
  • Colour
  • Warranty
    3 Years
  • Connector 1
    USB-C Male
  • Connector 2
    RJ-45 Female
C2G USB C to Ethernet Network Adapter - USB Type C to Gigabit Ethernet Adapter - network adapter
Network adapter
External
Interface (Bus) Type
SuperSpeed USB 3.0
Ports
Gigabit Ethernet x 1
2.34 cm x 7.66 cm x 1.56 cm
27.8 g
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
10Mb LAN, 100Mb LAN, GigE
Data Transfer Rate
1000 Mbps
USB 3.1
Apple MacOS, Microsoft Windows 7 / 8 / 8.1
3-year warranty
Network adapter
External
SuperSpeed USB 3.0
Ports
Wired
Cabling Type
Data Transfer Rate
1000 Mbps
USB powered, plastic housing
USB 3.1
1 x 1000Base-T - RJ-45
1 x USB-C cable (integrated) - 6.1 cm
FCC, RoHS
2.34 cm
7.66 cm
1.56 cm
27.8 g
Limited warranty - 3 years
10 °C
Protocol: Ethernet
Protocol: Fast Ethernet
Protocol: Gigabit Ethernet
Compatibility: Mac
Compatibility: PC
Brand: C2G
Price Range Ex VAT: 0 - 50
