Connect to this docking station with the included USB-C M/M cable and display HDMI, DisplayPort and VGA video content simultaneously, whilst also delivering power to ensure that a USB Type C equipped Chromebook, laptop, tablet, or smartphone is fully charged. Also transfer data with ease and speed, using the included USB-C data port or USB 3.0 ports that are backward compatible with USB 2.0. Overall, this docking station offers a lightweight, portable, and simple way to deliver video, transfer data and stay charged up. Supporting resolutions up to 1080p at 60Hz with simple plug and play allows this docking station to deliver a high quality video image to the connected display. Deliver up to 60W of charging power to the connected device. Transfer data up to 10Gbps using the USB-C port or 5Gbps whilst connected to the USB 3.0 ports.
Black -
Warranty
1 year -
Connector 1
(2) USB-C Male -
Connector 2
(1) VGA Female, (1) DisplayPort Female, (2) USB 3.0 A Female, (3) USB-C Female, (1) HDMI Female
- C2G USB C Docking Station with HDMI, DisplayPort and VGA - docking station - USB-C - VGA, HDMI, DP
- Product Type
- Docking station
- Docking Interface
- USB-C
- Video Interfaces
- VGA, HDMI, DP
- 12.7 cm x 6.32 cm x 1.37 cm
- 142 g
- Black
- 1-year warranty
- Product Type
- Docking station
- 12.7 cm
- 6.32 cm
- 1.37 cm
- 142 g
- Enclosure Colour
- Black
- 2 x SuperSpeed USB 3.0 - output - 9 pin USB Type A , 2 x USB-C - output - 24 pin USB-C , 1 x display / video - DisplayPort - 20 pin DisplayPort , 1 x display / video - HDMI - 19 pin HDMI Type A , 1 x display / video - VGA - 15 pin HD D-Sub (HD-15) , 1 x USB-C - input - 24 pin USB-C
- Cables Included
- 1 x USB-C cable - external
- RoHS 2 (2011/65/EU)
- Limited warranty - 1 year
- 0 °C
- 50 °C
