C2G USB-C 3.0 to 4-Port USB-A Hub
Quicklinx: DWR8WS00 Mfr#: 89053
The USB-C to 4-Port USB-A Hub expands USB capabilities by providing four USB-A ports for connecting peripherals to a single USB-C port. This hub is ideal for supporting keyboards, mice and other low-powered USB devices. Small, lightweight and portable, the hub is easily stored in a laptop case or pocket. With a transfer rate up to 5Gbps, it is fully USB 3.0 (USB 3.1 Gen 1) compliant, backwards compatible with USB 2.0 and USB 1.1 devices, and supports all USB peripherals, including keyboards and mice, smartphones, tablets, and other USB devices. This hub is compatible with any USB-enabled PC or Mac and is a plug and play device with no software or drivers required. This hub can be self-powered from the USB-C port, or may be used with the included AC power adapter when connecting power hungry USB devices such as a USB hard drive or USB to video adapter.
  • Colour
  • Connector 1
    USB-C Male
  • Connector 2
    USB 3.0 A Female
  • Warranty
    4 years
C2G USB 3.0 USB-C To 4-Port USB-A - hub - 4 ports
Hub - 4 ports
Subtype
USB
Ports
4 x SuperSpeed USB 3.0
4.05 cm x 9.06 cm x 1.6 cm
434 g
Apple MacOS, Microsoft Windows 7 / 8 / 8.1
3-year warranty
Hub - 4 ports
Enclosure Type
Desktop
Subtype
USB
Ports
4 x USB 3.0 Type A , 1 x USB-C
External power adapter
1 x USB cable - 6.1 cm
Plug and Play, FCC, RoHS
4.05 cm
9.06 cm
1.6 cm
434 g
Limited warranty - 3 years
10 °C
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
