C2G USB 3.1 USB C to VGA Adapter - White
Quicklinx: CHQHWS00 Mfr#: 88844
Colours:
£26.21 ex VAT
£31.45 inc VAT
This USB-C to VGA adapter is an ideal solution for utilising the video support built in to USB Type-C ports to feed a video signal from a USB-C equipped laptop, Chromebook or tablet to a VGA monitor or projector to display video. This adapter supports up to a 1920x1200 or 1080p resolution, allowing it to deliver a high-quality video image to the connected display. The compact design of this adapter makes it a perfect pair for BYOD (Bring Your Own Device) applications in education or corporate environments. Additionally, the USB-C connector is user-friendly and has a symmetrical design which is identical on both sides, which means it does not matter if you plug it in upside-down or right-side-up - it will plug in the first time, every time, whilst preventing damage to the connector port.
  • Colour
    White
  • Warranty
    3 Years
  • Connector 1
    USB-C Male
  • Connector 2
    VGA Female
C2G USB 3.1 USB Type C To VGA Adapter - USB C to VGA White - external video adapter - white
External video adapter
Bus Type
USB 3.1
Max Resolution
1920 x 1200
Interfaces Details
VGA , USB 3.1 (USB-C)
Enclosure Colour
White
3-year warranty
Bus Type
USB 3.1
Max Resolution
1920 x 1200
Interfaces Details
Plug and Play
32 g
Enclosure Colour
White
Limited warranty - 3 years
50 °C
Brand: C2G
