C2G USB 3.1 USB C to VGA Adapter - Black
Quicklinx: CHQGWS00 Mfr#: 88843
Colours:
More than 50 in stock
£22.79 ex VAT
£27.34 inc VAT
This USB-C to VGA adapter is an ideal solution for utilising the video support built in to USB Type-C ports to feed a video signal from a USB-C equipped laptop, Chromebook or tablet to a VGA monitor or projector to display video. This adapter supports up to a 1920x1200 or 1080p resolution, allowing it to deliver a high-quality video image to the connected display. The compact design of this adapter makes it a perfect pair for BYOD (Bring Your Own Device) applications in education or corporate environments. Additionally, the USB-C connector is user-friendly and has a symmetrical design which is identical on both sides, which means it does not matter if you plug it in upside-down or right-side-up - it will plug in the first time, every time, whilst preventing damage to the connector port.
  • Colour
  • Warranty
    3 Years
  • Connector 1
    USB-C Male
  • Connector 2
    VGA Female
C2G USB 3.1 USB Type C to VGA Adapter - USB C to VGA Black - external video adapter - black
External video adapter
Bus Type
USB 3.1
Max Resolution
1920 x 1200
VGA , USB 3.1 (USB-C)
Enclosure Colour
3-year warranty
Bus Type
USB 3.1
Max Resolution
1920 x 1200
Plug and Play
32 g
Enclosure Colour
Limited warranty - 3 years
50 °C
Brand: C2G
Price Range Ex VAT: 0 - 50
