This USB-C to VGA adapter is an ideal solution for utilising the video support built in to USB Type-C ports to feed a video signal from a USB-C equipped laptop, Chromebook or tablet to a VGA monitor or projector to display video. This adapter supports up to a 1920x1200 or 1080p resolution, allowing it to deliver a high-quality video image to the connected display. The compact design of this adapter makes it a perfect pair for BYOD (Bring Your Own Device) applications in education or corporate environments. Additionally, the USB-C connector is user-friendly and has a symmetrical design which is identical on both sides, which means it does not matter if you plug it in upside-down or right-side-up - it will plug in the first time, every time, whilst preventing damage to the connector port.
- C2G USB 3.1 USB Type C to VGA Adapter - USB C to VGA Black - external video adapter - black
- External video adapter
- Bus Type
- USB 3.1
- Max Resolution
- 1920 x 1200
- Interfaces Details
- VGA , USB 3.1 (USB-C)
- Enclosure Colour
- Black
- 3-year warranty
- Bus Type
- USB 3.1
- Max Resolution
- 1920 x 1200
- Plug and Play
- 32 g
- Enclosure Colour
- Black
- Limited warranty - 3 years
- 0 °C
- 50 °C
