C2G USB 3.1 USB C to VGA Adapter - Black
Quicklinx: CHQGWS00 Mfr#: 88843
Colours:
This USB-C to VGA adapter is an ideal solution for utilising the video support built in to USB Type-C ports to feed a video signal from a USB-C equipped laptop, Chromebook or tablet to a VGA monitor or projector to display video. This adapter supports up to a 1920x1200 or 1080p resolution, allowing it to deliver a high-quality video image to the connected display. The compact design of this adapter makes it a perfect pair for BYOD (Bring Your Own Device) applications in education or corporate environments. Additionally, the USB-C connector is user-friendly and has a symmetrical design which is identical on both sides, which means it does not matter if you plug it in upside-down or right-side-up - it will plug in the first time, every time, whilst preventing damage to the connector port.
  • Seamless connectivity
    The USB 3.1 USB Type-C to VGA Adapter bridges the gap between your USB-C device and VGA display, enabling you to project your work or entertainment onto a larger screen without the need for complicated setups.
  • High-quality video output
    Supporting resolutions up to 1920 x 1200, this adapter ensures that the quality of your video signal is preserved, delivering crisp, clear visuals on your VGA display.
  • Plug-and-Play convenience
    Designed with ease of use in mind, this adapter adheres to Plug-and-Play standards, eliminating the need for additional drivers or software installations. Simply connect and go.
C2G USB 3.1 USB Type C to VGA Adapter - USB C to VGA Black - external video adapter - black
External video adapter
Bus Type
USB 3.1
Graphics Engine
- up to
Max Resolution
1920 x 1200
Interfaces Details
VGA , USB 3.1 (USB-C)
Enclosure Colour
3-year warranty
Bus Type
USB 3.1
Max Resolution
1920 x 1200
Interfaces Details
Plug and Play
32 g
Enclosure Colour
Limited warranty - 3 years
50 °C
